Constant Current Source - NPN vs MOSFET
Robin Mitchell
Joined Oct 25, 2009
819
Hi all,
Quick question and more of a curiosity:
Is it better to use either an NPN or MOSFET for a constant current source as shown in the image below:
In my practice I found that NPNs give a better max current rating but I may be completly wrong.
kubeek
Joined Sep 20, 2005
5,793
There at least thee things that i can think of right now that will limit the available current.
With an NPN, you are limited to roughly the output current of the opamp times 10 or somewhere around that number. However the npn has only 0.7V between base and emitter, so you can get almost all of the current that you would if you took the transistor out.
With a mosfet you are not limited by the output current of the opamp, but the voltage between gate and source will be at least a few times larger than that of the bjt, which limits the available current with an N channel mosfet in this source follower configuration. With a P type common emmiter (source) the situation would be a bit different.
Thirdly you are limited by the power dissipation in the transistor, but I don´t see here one type being inherently better than the other.
dl324
Joined Mar 30, 2015
16,788
I think it's more a matter of personal preference and/or what parts you have on hand. I prefer to use transistors because I have a dozen different part numbers each for NPN and PNP transistors and 1 each for N/P MOSFETs. If I could find MOSFETs for a nickel, I might be inclined to use them more often.
For the opamps and supply voltages I typically use, BJTs give me more flexibility.
These days, MOSFETs have higher current ratings than BJTs.
#12
Joined Nov 30, 2010
18,224
In my practice I found that NPNs give a better max current rating but I may be completely wrong.
I think you are wrong. In terms of amp per amp gain, the mosfet has a bjt beat (at low speeds) every day. The limit which I have to consider is available voltage maximum. The bjt can operate will less voltage than a mosfet...in most of my circuits.
34,201
The BJT maximum current is limited by the op amps output current but it's higher than kubeek stated.
It equals the maximum op amp output times the BJT current gain which is typically about a 100 or more.
The gain of 10 is when you use the BJT as a switch and here it's used in the linear region.
Robin Mitchell
Joined Oct 25, 2009
819
Sounds like a MOSFET may better suite my needs! I am looking to source up to 15~2oA so a MOSFET may do better.
Quick question, why is the limit 10 x gain for an NPN anyway?
WBahn
Joined Mar 31, 2012
29,932
That would probably only be if you are using a power transistor -- in which case you are probably well past the capability of the opamp to feed it anyway.
For a normal transistor, since you want to keep it well out of saturation so that it can control the current, you are probably looking at a practical limit that is at least 100x the opamp output limit.
WBahn
Joined Mar 31, 2012
29,932
A common practical definition of "saturation" is when the current gain of a BJT has been reduced to 10. That's for small signal transistors. For power transistors the limit is often even lower. It's a somewhat arbitrary choice, but it works in many/most situations.
AnalogKid
Joined Aug 1, 2013
10,971
A bipolar power darlington is a good compromise. It doesn't require a high drive voltage like a power MOSFET, or a high drive current like a standard power BJT. Depending on the part type and circuit parameters, it can have a current gain of over 1000.
ak
ian field
Joined Oct 27, 2012
6,536
Hi all,
Its pretty much a matter of personal preference if you have plenty of voltage headroom.
Unless you use a logic level MOSFET, the voltage at a MOSFET source will never be more than a few volts less than the v-out high of the op-amp. For a typical power MOSFET; the VGSthr is around 6 - 8V. Occasionally the MOSFETs on PC motherboard buck regulators have VGSthr as low as 1.6V - only a fraction more than the Vbe of a Darlington transistor.
With a bipolar transistor; the op-amp must supply the base current, which is the regulated current divided by the transistor gain.
The MOSFET of course is voltage driven, so the op-amp pretty much doesn't have to drive any current.
sootydog
Joined Jul 23, 2011
7
I've built quite a few constant current circuits for device testing. My preferred configuration is to use a mosfet but with the load on the drain side to minimize the headroom issue. You could use a BJT in that configuration but there would be an error due to the base current being added to the load current passing through the sense resistor.
Sensacell
Joined Jun 19, 2012
3,420
The cool thing about using the MOSFET is that there is no base current error, you can use the source or drain as the output and the current is identical- because the gate basically draws no current.
Bordodynov
Joined May 20, 2015
3,174
When the supply voltage is high enough, the advantage for the FET. When the supply voltage is low (3-5 volts) for the benefit of a bipolar transistor. The supply voltage of the operational amplifier may be greater than that of the transistor. This will reduce the power dissipation of the transistor. I did one of my projects.
The field effect transistor can provide higher current, which is independent of the power operational amplifier.
ian field
Joined Oct 27, 2012
6,536
In the circuit posted by the TS; the resistor in series with the load samples *ALL* the current through the load and the op-amp adjusts bias to the power device accordingly - or to put it another way, the sampling resistor includes the BJT base current.
