Constant current source from a single LiPo cell at 5A
Discussion in 'The Projects Forum' started by newhobby, Feb 23, 2015.
Thread Status:
Not open for further replies.
  1. newhobby
    Mar 26, 2014
    24
    I need help identifying a constant current source circuit to power a laser diode at about 5A from a single LiPo cell.
    The Vf of the diode is about 1.9V.
    I'm not interested in off-the-shelf stuff. I'd like to build it from scratch.
    Is requesting help for specific chip selection something I can do or it is against the rules?
    Thanks,
    RI
  2. Dodgydave
    Jun 22, 2012
    5,134
    767
  3. newhobby
    Mar 26, 2014
    24
    The cell is 3.7V nominal and I'll have it limited to a range from 3.2 to 4.2V
    I'd rather have a switching circuit because this is for a handheld application and dissipating the resistor on top of the diode is going to be a task on its own.
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    What are you trying to do with a 10 Watt handheld laser?
    A few miliwatt can already be dangerous.
    Please read this page:
    http://www.repairfaq.org/sam/lasersaf.htm
    Bertus
  5. newhobby
    Mar 26, 2014
    24
    Yes, except it is a 5W diode.
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    5 Ampere X 1.9 Volts = 9.5 Watt.
    Do you have a specsheet of the laser diode?
    AGAIN what are you trying to do with the laser?
    In my job we use that kind of laser to burn clean the source of a massa spectrometer.
    It heats up the source to about 500 C.
    It is NOT something to play with.
    Bertus
  7. crutschow
    Mar 14, 2008
    13,469
    3,356
    I agree with bertus. You don't want to be playing with a hand-help 10W (or even 5W) laser diode. Either one can put an eye out instantly and/or rapidly burn a nice hole into you.
  8. newhobby
    Mar 26, 2014
    24
    My laser diodes typically have 50% efficiency :(
    I've already built a benchtop 20W laser device, so I can assure you I know what it is and this isn't going to be for a toy.
    My package is actually a triple 5W diode in three different wavelengths, so I'll have to have either 3 drivers or a way to switch which one I want to fire. That means that size is extremely important. I think there is no way I'll be able to fit 3 drivers in the pcb space I have.
    They are probably not going to be fired at the same time because the battery won't be able to handle the discharge.
  9. Dodgydave
    Jun 22, 2012
    5,134
    767
    ...#3 , well your better off getting one ready made from Ebay, good luck.
  10. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    At what are you "firing"?
    Will the beam be confined in a closed surrounding?
    Even reflections can be dangerous.
    Bertus
  11. newhobby
    Mar 26, 2014
    24
    This is not for a toy. I'm not interested on eBay stuff.
    This will be a commercial product.
    I'm after some guidance in selecting an IC and possibly a freelance job if necessary. I'm not interested in hearing how dangerous lasers are.
    I already know how dangerous they are and I have been unsuccessful in finding a suitable IC. That's why I'm here.
  12. Dodgydave
    Jun 22, 2012
    5,134
    767
  13. MrChips
    Oct 2, 2009
    12,623
    3,451
    A handheld 5W laser just doesn't sound right and we don't want to hear about it and possible adverse consequences.
    Hence this thread is closed.
Thread Status:
