Constant current source for a laser diode
Discussion in 'The Projects Forum' started by electrophile, Jan 24, 2016.
  1. electrophile
    Aug 30, 2013
    100
    I'm trying to replicate this circuit for a 2W laser diode engraver. I could understand most of the other components except the current source schematic (Pg. 5, Fig 4). I understand that the TLC271 is being operated in high-bias mode (cause the datasheet says that when the bias select pin is grounded its in high-bias mode), however, I do not understand how the combination of RV2, R16 and R18 works and what values need to be set. Any help would be appreciated. Thanks.
  2. ronv
    Nov 12, 2008
    3,403
    1,477
    They are used to cancel the offset of the op amp. I'm not sure why they are worried about it as they adjust the current anyway. I'm not crazy about that op amp. It also seems like there might be easier ways to pwm it.
  3. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    I believe the schematic in Figure 4 is labeled incorrectly. On the TLC271, pin 8 should be Bias Select, and pin 1 should be Offset In 1, and pin 5 should be Offset In 2. Perhaps there is a different package not in the datasheet. In any case, the circuit seems to be wired correctly for proper use.
    Ronv's explanation is correct.
  4. Dodgydave
    Jun 22, 2012
    5,158
    772
    Its just a constant current led driver, any op amp will do the job use the Tlc272 dual version or lm358.
  5. electrophile
    Aug 30, 2013
    100
  6. Dodgydave
    Jun 22, 2012
    5,158
    772
    As long as they can cope with your led current, they should work.
  7. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    Yes, but these aren't plug-in replacements, you'll have to redesign the circuit for these chips. Fortunately, the datasheets are very complete and give you lots of information to use.
  8. ronv
    Nov 12, 2008
    3,403
    1,477
    Do you have a data sheet for you laser diode? Sometimes they are a little more fussy than LEDs.
  9. electrophile
    Aug 30, 2013
    100
    This is what I could source from the web (attached). Also, I was trying to design for ST's ST1CC40 using their eDesign Studio software on their website. I was obviously trying to create a constant current source for LEDs and one of the design inputs was for something called "Rd (ohms)". I assume its the resistance of the laser diode which unfortunately is not listed in the datasheet. I calculated this value using the voltage (~4.5V) and current (~1.2A) required to turn on the laser. Is that right?
  10. ronv
    Nov 12, 2008
    3,403
    1,477
    I'm not sure what they mean by Rd. I'll try to look tomorrow.
    But for now, here is what I would recommend.
    Buy a good quality switch mode power supply (wall wort) rated at 3 amps or so rather than trying to build one.
    Then I think their constant current source can be made with more common devices. I can draw one up if you like.
    I haven't convinced myself that their fancy reference supply is needed - need to look closer at it.
  11. electrophile
    Aug 30, 2013
    100
    Yep I have a 12V, 10A SMPS power supply that I'll be using for powering the whole setup including the stepper motors and build a 5V supply off it to power my Arduino and the motor drivers.
    I'd really appreciate that. Thanks.
  12. electrophile
    Aug 30, 2013
    100
    Got it. Redesigning with these would be more simpler since they seem to be using common components and it would eliminate some of the other circuits that are in the original design.
  13. Colin55
    Member
    Aug 27, 2015
    204
    21
    You just need a 2 -3 amp DC power supply, a transistor, signal diode and a few resistors.
    The DC supply should be low voltage. As low as 5v
    You can get one on eBay for $2.00
  14. Dodgydave
    Jun 22, 2012
    5,158
    772
  15. ronv
    Nov 12, 2008
    3,403
    1,477
    Take a look at this one.
    It does not have isolation between the mico (PWM) and has just a simple adjustment for the power.
  16. ScottWang
    Aug 23, 2012
    4,933
    777
    Could you attach the asc file?
    Thanks.
  17. ronv
    Nov 12, 2008
    3,403
    1,477
    Sure.
    ScottWang likes this.
  18. electrophile
    Aug 30, 2013
    100
    Thanks @Dodgydave. This helps. I'm gonna try this since I think I have most of the components at home.
    Thanks @ronv. The help is much appreciated. I will try this one out too. For now I do not need PWM but a simple turn on and off and I think I can manage that with a simple optocoupler such as the 4N25.
  19. electrophile
    Aug 30, 2013
    100
    @ronv, Could you please attach the libraries and symbols for the potentiometer and the OPA743 op-amp?
  20. ScottWang
    Aug 23, 2012
    4,933
    777
    I was used the normal op amp to replaced it, but I still can't find the potentiometer, it's weird, I used the pot before, but I can't find it after I was updated a couple times later.
    The op amp is at the\lib\sym\opamp\opamp.asy
