Constant coltage on latching relay
Discussion in 'General Electronics Chat' started by Foulkesey, May 8, 2015.
  1. Foulkesey
    May 8, 2015
    6
    Hi guys,
    I want to install a dual coil latching relay, only problem is the voltage to the coils will not be pulse they would be constant but i also require relay to latch once all power is off.
    Is this possible?
    Cheers joe
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    The dual coil latching relays are not usually designed to have their coil powered continuously, and will likely overheat if you do so.
  3. Foulkesey
    May 8, 2015
    6
    Ok thanks, have you any ideas what else i could do, i need to add a relay controlled by 2 seperate switches with constant voltage, yet needs to latch in position once all power is off? Cheers
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Just use a momentary, spring-return, pushbutton switch to pulse each side of the latching relay.
  5. Foulkesey
    May 8, 2015
    6
  6. crutschow
    Mar 14, 2008
    13,508
    3,385
    How exactly are the two switches supposed to control the relay?
  7. Foulkesey
    May 8, 2015
    6
    This is what i have found i just need NO/NC contact i have 2 x seperate 12v switch lives to control the coil on the relay but i need latching for when there is no power
  8. crutschow
    Mar 14, 2008
    13,508
    3,385
    If you explain exactly what you are trying to do, then perhaps we can suggest the best approach.
    Why do you need it latched when power is removed?
