I am currently designing a simple data logger that will be deployed in the field for (hopefully) months at a time. It will be an ATMega 328 with a real time clock and an SD Card for data storage. Obviously batteries are critical to this application and owing to the various voltages etc. from different battery chemistry I can't finalise the design until I have chosen a battery technology. I have done A LOT of Googling and reading around the subject but I thought I would ask to check that I had got all the bases covered.
So what do I need to consider when choosing rechargeable batteries that will run with very low current (I'm expecting quiescent current well under 100uA and peaks of not more than 150mA) for a long time. Obviously self-discharge is critical but is there anything else? Are some battery chemistries better suited to low discharge rates than others? Are some more rugged (wrt damp, temperature, etc.)? Do some cope better with deep discharge?
At the moment I can see pros and cons for low self-discharge NiMH, lead acid and lithium and I'm not sure which was to jump. The advantage of lsd NiMH is that I can nicely get 4.8V and therefore can run the ATMega without a regulator. I could do this with 3.7V lithium but the SD card needs 3.3V (regulated) and so there is very little overhead to play with in that approach. The advantage of lead acid is the cost and capacity I can get 10AH for around £16, so I could afford to lose some to self-discharge and a regulator
Thoughts and suggestions please!
