I want to build a transformer which will be driven with a square wave and provide an output voltage of 10-20kV at the lowest current possible.
The transformer's secondary coil will be like that of an ignition coil where one side of the secondary is grounded with the primary coil.
The transformer will use a ferrite core and operate in the RF range.
What factors need to be taken into account when building a transformer of this type???
What kind of resistance would I need in the secondary winding to limit current as much as possible when operating at 10-20kV?
How can I make the transformer have a high leakage inductance to limit current?
It seems to me like there's a lot I don't know about building a transformer, and using high voltages I might just be better off buying one. Where can I get a 20kV transformer that can operate in the RF range?
