Conservation of energy
Discussion in 'Physics' started by braddy, Oct 26, 2005.
  1. braddy
    Dec 29, 2004
    83
    Hi can someone help me with this problem:
    If a .75 kg block is rested on the top of a vertical string of force constant 45N/m, how much potential energy is stored in the spring relative to its equqilibrium configuration?
    I tried to use the conservation of energy , but it did not let me to a good conclusion.
    Thank you
    B
  2. n9352527
    Oct 14, 2005
    1,198
    The force exerted down by the block on the spring is
    F = mg
    The spring is compressed for a length of h due to this force
    h = F / force constant
    Energy stored is either the potential energy of the block
    E = mgh
    or the potential energy stored in the string
    E = Fh
    They are both equal.
  3. braddy
    Dec 29, 2004
    83
    thank you very much
