conservation of charge r energy?
Discussion in 'General Electronics Chat' started by chandraprakash, Dec 28, 2006.
  1. chandraprakash
    Dec 28, 2006
    10v
    == 3f
    ___
    a
    |---||(3f)----|0v
    |----||(6f)----|0v
    what ll b the voltages across the 3f and 6f if 3f was connected to a 10v source initially..ll they follow conservation of charges or energy?...
  2. sci-3d
    Aug 22, 2006
    51
    Ideally, they should conserve both charges and energy.
  3. chandraprakash
    Dec 28, 2006
    if u consider charge conservation u lla voltage of 10/3 across both the capacitors...but energy s not conserved..
    1/2*3*10^2!=1/2*3*(10/3)^2+1/2*6*(10/3)^2...
  4. n9352527
    Oct 14, 2005
    1,198
    There is missing energy associated with transfer of charge between a charged capacitor to an empty one. If you have two capacitors with the same value, and one is charged to say 10V and the other is empty, then upon connecting both of them in parallel, the final voltage across both of them is 5V. This is calculated through the charge conservation, i.e. Q = CV.
    However, the total energy stored in the capacitors is now a half of the initial energy (from 0.5CV^2). The explanation is a bit sketchy, but the best I could find is the so called Lacy-McCabe law, where the potential of doing work (or in this case stored energy) can only be realised by doing work and not by passing the stored energy directly without changing form.
    This is an old problem, which has so many explanations and approaches that it could end up more confusing for the reader. There are also explanations that the energy is dissipated in the transfer (electromagnetic, heat, etc).
    Have a look at this paper http://ej.iop.org/links/rEIkex2sU/qH-lBlWa2xG04EyDav5vpA/pe7202.pdf
  5. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    That link is not there, it's to an article that has to be paid for and it's a temporary link or one only you have access to.
  6. n9352527
    Oct 14, 2005
    1,198
    You are right. I apologise.
    You could search for Lacy-McCabe Law pertaining to transfer of charge between two capacitors and conservation of energy instead.
