Connectors
Discussion in 'The Projects Forum' started by jismagic, Oct 15, 2013.
  1. jismagic
    Sep 7, 2013
    77
    I am looking for how much current some of the connectors can handle
    DB62,EDAC,Molex etc.
    Any web link which can give these info
    thank you:)
    jis
  2. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Have you tried the DigiKey site, The selections usually include a manuf PDF.
    Max.
  3. Tealc
    Member
    Jun 30, 2011
    140
    10
    Molex supplies dozens of connectors so you'd need to know specifically which ones you are interested in.
  4. mcgyvr
    Oct 15, 2009
    4,793
    976
    find the exact connector you want and simply look at its "datasheet" or "specifications"
    ampacity is typically listed or is mostly dictated by applicable wire size.
    A "DB62" connector from EDAC or Molex will typically be 5 Amps max.. Its not really meant to carry power but rather "data"
