hi all,
I am making a project of which has a 400mm x 400mm x 100mm adaptable box that has 16 cables going into it of which are 0.5mm 2 core or 0.75mm 3 core...the 3 core flex's are 230V mains cables with a max load of 5 amps. Im looking to redesign the whole thing so it can be unassembled easier and assembled and at the moment I have 16 cables going into the box inside compression glands.
I am looking to cut the cables a few inches from the entrance to the box, leave the glands on and put inline connectors on but using something like the below 16 times will not look good..
I could redesign and build the box again but it would be to time consuming
