Connector pins to blocked
Discussion in 'General Electronics Chat' started by gotumal, Apr 21, 2008.
  1. gotumal
    Thread Starter Active Member
    Mar 24, 2008
    99
    Hi reader,
    I need to block some pins of relimate connector (female type). Is there any common practice to block it. may be with some plug etc made up of rubber plastic which can be inserted in to the pins.
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Plastic pins are sold for that purpose. They look like tiny finishing nails. I don't believe they are brand specific, but you do need to know the pin size and probably shape (square or round). If that is not practical for you, I would just epoxy or other glue a small sliver of plastic in the hole. Worst case, insert a spare pin from the mating plug and glue it. John
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    You could build a short extension cable that passed through all of the signals you wanted to maintain and omit any that you wanted to leave disconnected.
    hgmjr
  4. gotumal
    Mar 24, 2008
    99
    Thanks John,
    Actually I would like to tell a little background. You may find it useful.
    One of the requirement of our product is to have a "pokayoke". For some reason one of our supplier can't provide a polar connector. So I wanted to remove two odd no of pins of that connetor and cocequently on it's mating part on the board.
    I would implement one of the ways suggested by John.
