Connector for signal and power - Wires unsolder-ed?
Discussion in 'The Projects Forum' started by vol_, Apr 30, 2016.
  1. vol_
    Dec 2, 2015
    93
    What do you think? The unsolder-ed wires could make a significant difference in long time terms? Maybe the contact of the wire with the pins would deteriorate, due to corrosion, as years passing?
    And what is your opinion, everyone, about using connectors in audio signal paths and in power supply paths (use of power connectors here)?
  2. nsaspook
    Aug 27, 2009
    3,013
    2,357
    My opinion matters not. There is a vast number of reliability reports (usually on the datasheet for the connector) on a huge number of different connectors , pins and sockets.
    http://www.newark.com/wcsstore/Exte...orefront/te_amp/Materials-And-Reliability.pdf
    The odds that a device will be dropped or have a soda spilled inside destroying a properly terminated (solder or crimp) well-made connector is much greater than that connector failing internally just from age.
    I have crimp connectors on machines that are 20+ years old where the electrical connections are just as good today as then. Those signal and power connections are as good or better than soldered connections.
    http://cdmelectronics.com/wp-content/uploads/2014/07/MRE_SERIES.pdf
    vol_ likes this.
  3. SLK001
    Nov 29, 2011
    851
    243
    Crimp only - do NOT use solder. A properly crimped connection is metal-to-metal and is oxygen free, so there will be no corrosion. If you don't think this is true, just know the the US military will NOT accept any wire connector that is soldered (if you've ever been through a US DOD system acceptance proceedure, you know what I mean).
    And @nsaspook, your opinions DO matter! Probably better than most.
  4. MrChips
    Oct 2, 2009
    12,635
    3,453
    It's a lot more complex than that.
    You need to identify your target market and environment.
    There is a reason electronics are manufactured for different markets: commercial, industrial, military.
    Is this for hobby, consumer electronics, automotive, industrial, military, aerospace?
    What is the environment?
    Temperature extremes?
    Moisture, vapor, humidity, immersion, condensation, corrosive?
    UV exposure?
    Vibration, g-forces?
    Tension, compression forces?
    Insertion-retention force
    Assembly, disassembly, repair, service
    Size, strength, durability
    Metal content, plating material
    Plastic content in connector, cabling
    Ohmic resistance, current, voltage, AC, DC
    Cost, manufacturability
    Color, aesthetics
    Did I overlook anything?
