connection to a servo motor
Discussion in 'General Electronics Chat' started by bug13, Jun 13, 2013.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    Do I need to put a free wheel diode and a cap in parallel with servo motor? I assume those two components are not necessary, as it's internal circuit should have those already??
    edit:
    Is it recommend to have a series resistor in the signal line to a servo motor?
  2. Dodgydave
    Jun 22, 2012
    5,141
    767
    Most servo/stepper driver chips have back emf diodes built in, which driver are you using?
  3. bug13
    Feb 13, 2012
    1,213
    38
    The one I am playing with at the moment doesn't need a driver, all it needs is a PWM signal like this.
    And I just connect it directly to the PWM of a MCU, but I am thinking long term reliability, so I am just wondering if I need free wheel diode and cap in parallel in power supply, and resistor in series to the PWM signal
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    That has nothing to do with "servo motors", what you are talking about is an "RC servo".
    It's good to have a decent sized cap on the power leads to the RC servo. The cap on the little PCB inside the RC servo is very tiny.
    bug13 likes this.
  5. bug13
    Feb 13, 2012
    1,213
    38
    Arrrh, so servo motors are different from RC servo motor, I always thought they are the same but just different in size, thanks for that!
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Servo motor;
    and RC servo;
    bug13 likes this.
