connection problem with IR21362,and then no output signal at LO(at least)
Discussion in 'The Projects Forum' started by jean120, May 8, 2016.
  1. jean120
    Jan 24, 2016
    75
    Hello,Dear I connected the IR21362 as follows but I am not succeeding to output an signal from it;the configuration pins are connected as follows
    Pin 8:FAULT:Not connected
    pin9:ITRIP not connected
    pin 10:EN-----------------VCC
    Pin11:RCIN:resistor and capacitor added as indicated in the datasheet of the component
    pin12:VSS------------------Gnd
    pin13:COM-----------------Gnd
    could you suggest how I may connected this component,it gives no signals(at least the LO may be obtained)but I don`t get them
    Please help
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    How do you have them connected. Half bridge or full bridge, the bottom mosfet must be on and the top PWM signal for the bootstrap to charge.
    Max.
  3. jean120
    Jan 24, 2016
    75
    I have not yet connectedthe IGBT bridge but I thought I can even get the signal at LO output even if the low IGBTs are not yet connected!!
    Please help
