I have searched in Google, but i don't get it circuit only for //. please tell.
No, it is not possible to connect two 3-phase transformers in series.I am asking because is it possible for connecting 3 phase transformer in series?? as till now i have connected single phase only.
this is not academic exercise!!
Well, in the old days they were called "generators", but the more appropriate title would be dynamo, as they had commutators.All depends on who you ask........The term Generator, as applied to automotive, usually refers to DC for the chassis electric.
No, its OK..I really didn't want to confuse him with outdated stuff.
This is done on an instrument called a "growler" [google ] which is simply an AC coil, on a laminated frame similar to a transformer, only shaped square for the coil, with an extended " V block " shaped section to rest a subject armature on.Hi,
how to check the armature of any motor like DC or ac drill machine.........
A metal strip is then played against the top of the armature under test, and if magnetically attracted, indicates a fault in the armature. no attraction = armature is OK http://www.youtube.com/watch?v=yXQ0heuV6VE
An adjustable hi-pot -- High potential -- machine is also desirable, to stress check the insulation between the armature and commutator, and the shaft they are mounted on.
A hi-pot produces a higher voltage, 500-700 over rated nameplate voltage, at preset small amperages.....200 mA max on the one I use, any faults in insulation will show instantly.
Theory being, if the insulation holds at the elevated voltage, it will be OK under normal load.
