Problem: When current is enabled, my load detection indicator LED stays on whether the load is attached or not.
My constant current power supply, circuit attached, is working just great at breadboard stage EXCEPT for the most simple task, detecting the load.
In the diagram, everything to the right of the load is simply for detecting the presence of the load, and lighting up an LED indicator. The circuit as shown works great when the main current flow is disabled; no load connected=LED off, load connected=LED on. But enabling the current causes the LED to light constantly regardless of whether the load is connected or not.
I can't seem to find the magic resistor values that fix this. If I raise the load detection comparator reference voltage from ~0.24v to something much higher, eg. 2.5v, the LED flickers when the load is on and stays on constantly when it is removed. I believe it may be flickering a bit even when the reference voltage is 0.24v. How can that be? It's not the power supply itself, since other LEDs lit by the same power are not affected.
Also, I've tried using the optional resistors shown to protect the comparator's inverting inputs. They don't seem to matter one way or the other. Is there a reason to leave them in place or can I simply omit them?
[Update] To be precise, R22 is currently 0.47Ω and the current flow when enabled is ~0.5A.
