I'm also happy to share your knowledge in this field, because the learning curve here is so steep. Anyways, after I read your reply, I thought I would try to draw what I meant and post it. But when I started, I quickly realized what the problem was. I.e., controlling individual pins would be impossible. I'm glad we had this discussion. In general though, if I have a choice between common emitter and common collector, what should be my criteria for choosing one over the other?No, it won't work at all. All the LEDs in the display have their cathodes connected together. If you connect all the anodes together, then all the LEDs are in parallel, so they'll ALL light at once!
If you connect all the collectors together, then whenever ANY transistor turns ON, there will be a path to 0V and ALL the LEDs will light. You would lose the individual control of the segments.
Very confusing.opens a transistor.
Guilty. I wouldn't have used the term except for the earlier reference to "opening" a path to ground. [oops, that may have been a different thread] I guess I also tend to think of the water analogy, with the transistor as a valve which you can "open" to get flow. That's what happens when you get a chemical engineer talking about electronics.Very confusing.
Is it 0 or is it +2.4, which you mention in the next sentence? I'm a little confused.its output goes to near 0V
Does it mean that it can tolerate only a low current load? I.e., the resistance of the load needs to be rather high?Its sourcing current is very low.
That's not a simple question to answer. In this case, either common emitter or emitter follower can be used, because the incoming signal (from the 4026) swings over the full voltage range that you need at the output, to drive the display. In many cases though, the device needs to switch a higher voltage than the signal controlling it, and that's when a common emitter configuration is useful. Google or Wikipedia "open collector" for more.In general though, if I have a choice between common emitter and common collector, what should be my criteria for choosing one over the other?
Agreed.("Opening" a transistor)
Very confusing.
It probably should be. The moderators can make it so, if they want.Can I ask an unrelated question? Maybe this should be a new thread, let me know.
Wayne has answered this pretty well.(Sourcing and sinking)
As I understand it, "sinking" is putting signal into a pin. Of course the weird part for me is that you might want to put voltage into a pin to read it.
Yes. "Weak" means high resistance and low current. For example, a dead 9V battery might measure 8V on a multimeter, but if you connect a light bulb across it, the light bulb won't glow at all, and if you measure the voltage across the light bulb, it is nearly zero. You would say the battery is "weak" because as soon as you try to DRAW CURRENT FROM it, the voltage sags to nearly nothing. When you measured it with a multimeter, it seemed to have some energy left, but a multimeter has a high input resistance (10 megohms usually) and draws almost NO current.In an experiment he uses a TTL counter chip that is at first connected directly to a group of LEDs. The LEDs are lit up but dimly because the author says TTL output signal is "weak".
You're on the right track. The effect of connecting an LED from the output to ground directly, or with a low-value current limiting resistor, depends on the characteristics of the output. In the case of a TTL output, 47K was unnecessarily high, and you would get a brighter LED with no damage if the resistor was lower, say 1K, which would give an LED current of less than 1 mA.Side Note: after that statement, it was strange for me to see 47K resistors with each LED because I thought, if the signal is small, why put such a big resistor next to each LED? My thought it's because it's not the signal that is weak, but that the chip will tolerate a very small current to be flowing through it. Is that correct? Otherwise if we have any voltage on a pin, with a small enough resistor, we can cause any kinds of current to flow.
Right. That was normal practice back in the dim dark days of TTL and LS. The outputs can sink significant current, but source current only weakly. I think of this as being like a strong spring and a weak spring. (The tension type of spring that pulls its ends together.) When the TTL/LS output is high, it's like a weak spring to VCC, and is easily loaded down (a weak current source). But when it's low, it's a relatively strong spring to GND (a strong current sink).So, the modification proposed is to connect the "+" of each each LED to the positive rail and the "-" to the output pin. This way when the output on the pin is high, the LED is dim, and when the output is low, the LED lights up. That is the opposite of what we want, so, an inverter is placed between the TTL and the LEDs.
OK, I get it, it's old, but I still want to use them. That's part of my learning. And if an LED blows up or even ten of them, that's fine. The way you talk about it is like there should be a funeral ceremony after an LED dies. Lighten up a little, would you?I never tried sourcing current from an old TTL IC into the anode of an LED because I stopped using old TTL ICs about 37 years ago.
Why blow up electronic parts? Why do things wrongly?OK, I get it, it's old, but I still want to use them. That's part of my learning. And if an LED blows up or even ten of them, that's fine. The way you talk about it is like there should be a funeral ceremony after an LED dies. Lighten up a little, would you?
But wouldn't connecting the LED with its positive end to the positive rail and the negative end to the output pin constitute putting voltage into an output pin?Sourcing and sinking mainly relate to OUTPUT pins, that are being used to DRIVE something with current. "Putting voltage into a pin" applies to INPUT pins.
Is the high resistance because of the internals of the chip or the load?Yes. "Weak" means high resistance and low current. For example, a dead 9V battery might measure 8V on a multimeter, but if you connect a light bulb across it...
Because doing things wrongly is how humans (or most of them) learn and because I don't know enough to avoid making mistakes in this area. If I was en EE major, your exhortations would be appropriate. I'm not. I'm going through a BEGINNING electronics book. At this point, if I see I smoke coming out of a component, I go grab a camera.Why blow up electronic parts? Why do things wrongly?
If you design the circuit properly by not exceeding the maximum allowed current shown on the datasheets then everything works without any smoke.
I have used thousands of transistors, LEDs and ICs in my career and I have NEVER blown one up.
by Jake Hertz
by Duane Benson
by Aaron Carman
