connecting PT100 to uController
Discussion in 'The Projects Forum' started by eric_s88, Nov 6, 2013.
  1. eric_s88
    Apr 20, 2011
    157
    Hi everybody :)
    I'm going to measure a surface temperature with pt100. what I got from this sensor is that, its resistance varies with the temperature. and the "100" stands for 100 \Omegaresistance in 0 degrees. and should have a current source to transform the resistance to a voltage and feed this to uC adc. (10bit)
    my problem is how to design current source ? would it be right to use current source ICs ? and how much big should be that current ?
    please help me in any useful information about driving and running this sensor .
    thank you :)
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Here is something I did years ago: (never throw anything away). Stare at it for a while, and come back if there is something you dont understand.
  3. Dodgydave
    Jun 22, 2012
    5,159
    772
    one here for an Arduino..
    eric_s88 likes this.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    I question why, in that circuit, they start with the bridge unbalanced?
  5. Dodgydave
    Jun 22, 2012
    5,159
    772
    Maybe starting at a different temperature than yours, alter the bridge resistors to suit your design
