Connecting PSU to mains "Wrong way/polarity"
Discussion in 'General Electronics Chat' started by snowboy, Dec 26, 2015.
  1. snowboy
    Oct 4, 2014
    10
    This might be a stupid question as I can't find any other post asking the same or don't know the wording to search it correctly.
    I have few of these cheap 220V to 12v/10A switched power supplies from ebay. It has Ground, N and L in. What would happen if the Neutral is connected to L and L is connected to Neutral? From what I remember from the school it should not matter (diode bridge?), but it's been so many years.. :)
  2. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Yes, you can connect L-N N-L vice versa
  3. ISB123
    May 21, 2014
    1,240
    531
    Doesnt matter its AC.
  4. snowboy
    Oct 4, 2014
    10
    Thanks for the quick reply and confirmation!
  5. ErnieM
    Apr 24, 2011
    7,443
    1,628
    Well... It may seem to work but you may have serious safety issues lurking there depending on what else is in there, if nothing else than the layout would expose more of the neutral connections over hot connections.
    Connect it properly. If you already wired it up you probably did not damage anything, so just turn it off and correct the mistake.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  7. snowboy
    Oct 4, 2014
    10
    I live in Finland, and yes, I can't tell which pin is neutral without tearing the wall socket. Hence the question.
