connecting mosfet driver ic
Discussion in 'General Electronics Chat' started by assassin___0, Mar 8, 2013.
  1. assassin___0
    May 10, 2011
    19
    I want to use the ic driver ISO5500 the digikey part number is 296-34888-5-ND
    I'm going to use it to drive a mosfet, not an igbt. The pwm signal is 3.3V and the output I want is 5V. Here are some of my questions:
    - If I don't plan on using reset or fault signals, do I just not connect them or should I give it input supply voltage?
    - I don't plan to have any negative voltages so both Vee-p and Vee-l are grounded, right?
    - Lastly, what do I do with Ve (pin # 16) since this is mosfet not igbt?
  2. shortbus
    Sep 30, 2009
    4,095
    1,681
    Don't know if this can be used on a mosfet. It looks like it supplies a negative voltage to the gate, to suppress tail currents, in the IGBT. This would not be good for a mosfet.
  3. assassin___0
    May 10, 2011
    19
    Never mind, I found out the output voltage is too much. I can't supply 5V, so i'll just have to forget about this idea. Thanks for the reply
  4. nigelwright7557
    May 10, 2008
    488
    71
    Try using a TC4420 mosfet gate driver.
