I am looking to connect a series of Lithium batteries in parallel for some devices I am making. These batteries are going to power any device I hook up to the circuit at the battery voltage, that is they are going to be in parallel. What I am looking for is a method of connecting Lithium batteries in parallel that have differences in charges without them trying to charge each other (and subsequently catch fire).
I was going to hook them up in parallel and put diodes to restrict the current flow from any cell in one direction thus preventing one battery from charging any other. The diodes I was going to use had a break down voltage larger then any voltage difference the batteries might see in each other so I think they would be safe. However, I don't like this solution since the constant voltage loss from the diode is something I'd like to avoid.
Is there a better way to do this?
