Connecting Heating Element to Thermo Regulator
energy2020
Joined May 30, 2012
Hi all,
i am an electronics illiterate person so please be patient with me.
in my pursuit to diy a home made sous vide machine, i have purchased the following :
1) a heating element which is connected to a powercord n a 3 pin wall plug
2) a thermostat regulator with a power cable and a thermocouple.
how do i hook it up? hope some of u could assist me :)
#12
Joined Nov 30, 2010
18,224
Apparently you power up the thermostat and use that to power the heating element. Does the thermothingy have an outlet with which to plug in the heater?
Potato Pudding
Joined Jun 11, 2010
688
Many thermostats are on off only, and can have a fairly wide hysteresis range.
You might need to get a PID type instead. Proportional Integral Derivative controllers will avoid the heating and cooling cycles of a crude more basic thermostat and should provide a temperature that is controlled to within half a degree.
#12
Joined Nov 30, 2010
18,224
Many cooking chores do not require accuracy to within 1/2 degree.
No need to overcomplicate this.
