How do I get the following 70.7 line audio distribution system to work simply with tube guitar amps without causing a catastrophic transformer failure? Do I need to place a high wattage resistor somewhere in the circuit to dissipate heat and to avoid high undamped flyback peaks?
I would like to use a large well-insulated crawl space to house speaker cabinets and microphones. The source tube amplifiers (various 50 watt amps), mic preamps and the Digital Audio Workstation will be in another room over 70 feet away. I will be running 16 gauge speaker wire to the cabinet(s).
This whole idea came about because I found a schematic of the Newcomb Pathfinder PA tube amp that a couple of people have been converting to use as a guitar amp. The schematic for the Pathfinder below shows 70v and 25v output options along with the regular low impedance low voltage outputs.
Initially I could only find autotransformers through an internet search. However, after doing an extensive search I found that Edcor manufactures single phase transformers for both amplifier output and speaker distribution. The Atlas Sound AT-100 100 watt 70volt attenuator is a popular product but I cannot find a schematic of the device online. What is drawn on the schematic is drawn by me and not confirmed.
