connecting gsm with arduino and dialling number from hex kepad
Discussion in 'Embedded Systems and Microcontrollers' started by bobparihar, Dec 26, 2014.
  1. bobparihar
    Jul 31, 2014
    93
    i want to dial a number from hex keypad to call..
    iam using interrupt method
    hex keypad uses 74c922 keypad decoder ic
    DA pin of 74c922 IC is connected to External interrupt pin 2
    whenver the button is pressed an interrupt is invoked and the corresponding 4bit number reads by MCU at pin 4,5,6 and 7
    Code (Text):
    1.
    2. #include <LiquidCrystal.h>
    3. LiquidCrystal lcd(13, 12, 11, 10, 9, 8);
    4.
    5. // incoming serial byte
    6. int number[10];
    7. int a, count=0;
    8. void setup()
    9. {
    10. lcd.begin(16, 2);
    11. for(int pin=3;pin<7;pin++)
    12. {
    13. pinMode(pin, INPUT);
    14. }
    15. attachInterrupt(0, key, RISING);
    16.
    17. // start serial port at 9600 bps
    18. Serial.begin(9600);
    19. // wait for a while till the serial port is ready
    20. delay(100);
    21. // send the initial data once //
    22. }
    23.
    24. void loop()
    25. {
    26. while(number[9]=='\0'); //wait till number array is full
    27.
    28.
    29.
    30. lcd.clear();
    31. for(int i=0;i<10;i++)
    32. {
    33. lcd.print(number[I]);
    34. }
    35.
    36. Serial.print("ATD");
    37.
    38. delay(100);
    39. for(int i=0;i<10;i++)
    40. {
    41. Serial.print(number);
    42. delay(30);
    43. }
    44. serial.print(';');
    45.
    46. delay(100);
    47. Serial.write(13);
    48. delay(100);
    49.
    50. while(1);
    51. }
    52. void key()
    53. {
    54. a=PIND&0xF0;
    55. a=a>>4;
    56. number[count++]=a;
    57. lcd.print(a);
    58.
    59.
    60. }
    61.
    Moderators note: Please use code tags for pieces of code
  2. shteii01
    Feb 19, 2010
    3,504
    512
    Ok...
  3. bobparihar
    Jul 31, 2014
    93
    What????
