Connecting a usb device to program a microcontroller
Discussion in 'The Projects Forum' started by dasandru, Feb 1, 2009.
  1. dasandru
    Jan 31, 2009
    How is this done ? If I have a microcontroller IC how to I get code onto it? I want to use USB, how would I configure a schematic to have this happen. Also I know that each microprocessor is different, but will I need to have some internal bootloader configured on the ROM to be able read the code or are most of these programmed in already, if I had a compadible compiler, will I be able to create a .hex file or something similar plug in the USB chip, and transfer away.?
    thanks, clueless
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
