The 555 could drive 200mA into the base of your switching transistor. If that transistor had a beta of 5, you'd Ic would be an amp. If you need more drive current, use a darlington instead of a single transistor.Yes you are right but I want to use the gate driver because for two reasons
with the 555 the signal deasappear once the Vin is larger than 7.5V
my device needs Ig abaout 1A to swich correctly and the 555 is not able to delivre such a current
If you're timer won't work with Vin > 7.5V, check your circuit and the timer; any voltage between ground and VCC should work.
