connecting a single chanel driver to an IGBT
Discussion in 'General Electronics Chat' started by kanoun, Apr 10, 2015.
  1. kanoun
    Jan 29, 2015
    41
    Dear All
    I'm trying to make swich measurement on an IGBT and I'm getting a hard time to connect the driver. you can see in the attachement the setup I did. Could you please help and comment. just for information:
    the output of my timer is 200µs at 7V and 50ms at 0V.
    the driver I'm using is this one http://www.irf.com/product-info/datasheets/data/irs2117pbf.pdf
    Many thanks
  2. crutschow
    Mar 14, 2008
    13,479
    3,366
    Are you using the IRS211(7,8) or the IRS21171 driver?
    The first two require a minimum of 9V logic level to give a high output level.
  3. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
    How come you are using a high side driver for a simple single mosfet?
    Max.
  4. kanoun
    Jan 29, 2015
    41
    do you agree with the set up ?
  5. kanoun
    Jan 29, 2015
    41
    it is not allowed ? I'm new in this area so please help :)
  6. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    Hi kanoun,
    Why don't you just drive the transistor controlling the relay directly from the 555 timer? The timer can sink/source 200mA.
  7. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
  8. kanoun
    Jan 29, 2015
    41
    I need more current
  9. kanoun
    Jan 29, 2015
    41
  10. crutschow
    Mar 14, 2008
    13,479
    3,366
    You didn't answer my question, so I can't answer yours.
  11. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
    What is the nature/type of load you are switching.?
    Max.
  12. dl324
    Mar 30, 2015
    3,376
    651
    Don't understand. The timer would be driving the transistor you're using to switch the inductive load. What needs more current?
  13. kanoun
    Jan 29, 2015
    41
    that could be the problem :) I'll try the 10 V or more :)
  14. kanoun
    Jan 29, 2015
    41
    one more probleme with the timer I was not able to go further thant 8 V as input ... beyond 7.5 V the signal deasappear ... Very strange but right :(
  15. kanoun
    Jan 29, 2015
    41
    inductance
  16. kanoun
    Jan 29, 2015
    41
    now could you answer :)
  17. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
    Still not sure why the IR High side switch, it seems redundant?
    Max.
  18. kanoun
    Jan 29, 2015
    41
    IR ? what do you mean ?
  19. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
    IRS211 single high side driver. Usually intended for high side Mosfet operation.
    Your load is shown in the Drain/collector so direct drive from the 555 should be possible.
    Max.
  20. kanoun
    Jan 29, 2015
    41
    Yes you are right but I want to use the gate driver because for two reasons
    with the 555 the signal deasappear once the Vin is larger than 7.5V
    my device needs Ig abaout 1A to swich correctly and the 555 is not able to delivre such a current
