connecting a Linear actuator to Relay Switch?
Discussion in 'General Electronics Chat' started by shrivle, Nov 20, 2013.
  1. shrivle
    Nov 20, 2013
    6
  2. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    You may discover a short (literally) life of this circuit. You should employ interlocks via multi pole relays.
  3. inwo
    Nov 7, 2013
    2,435
    315
    What voltage?
    Motor size?
    Will that timer work on DC supply?
  4. shrivle
    Nov 20, 2013
    6
    Hi, switch and actuator are both 24v DC.
    actuator is a high speed 140mm/s
    those diagrams are just guess work:)
  5. shrivle
    Nov 20, 2013
    6
  6. inwo
    Nov 7, 2013
    2,435
    315
    What I meant about timer working on dc, is it's marked "source ac" I believe.
    Also, what do you have in mind to initiate action?
    When powered on, a single "time delay" will run your actuator out for a set time (or in). Then reverse and continue in reverse until something switches to restart the timer.
    A limit switch on one end of stroke?
  7. inwo
    Nov 7, 2013
    2,435
    315
  8. shrivle
    Nov 20, 2013
    6
    brought it off ebay for $5 & they have sent me the AC version and not DC. It's not worth the hassle of sending it back for a refund.
    Might have to invest in this one, looks like they are more suitable for linear actuators, they also have a easy to follow wiring diagram:)
    http://www.firgelliauto.com/product_info.php?cPath=99&products_id=269
    I put 24v DC into it and the power light comes on then makes a click noise just as the second light comes on (which i presume is the contact closing). It is a 0.2-5 second timer. I have never used one before, just wondering if these when used normally will make multiple clicking noises, with each click at the interval set on the timer?
    ow well back to the drawing board:)
    Thanks for your help
  9. shrivle
    Nov 20, 2013
    6
    yes that looks very similar, might have to get one from the firgelliauto.com website, they also should be able to walk me through installation:)
    the ones on ebay range from $50 to $100
  10. shrivle
    Nov 20, 2013
    6
  11. inwo
    Nov 7, 2013
    2,435
    315
    The link wasn't a shopping suggestion, just a link to data sheet.
    Any 24vdc multi-function timer will work.
    Some may not be dpdt relay output, but you should really use an external relay for switching load.
    The wiring will work similar to your sketch. To be practical it needs diodes across each contact and snubber circuit across commons (power in).
