Connecting a DSC House Alarm Keybus to Raspberry Pi
Discussion in 'The Projects Forum' started by Nitrogen, Jul 29, 2013.
  1. Nitrogen
    Jul 28, 2013
    Hi all,
    First time poster and electronics newbie here.
    I have a DSC 1864 House Alarm and I want to connect up my Raspberry Pi's GPIO to the Keybus (a serial data communication protocol used by the alarm).
    Info:
    The Keybus is a 4 wire serial data bus - +12V, Ground, DATA and CLK.
    The clock runs at 1khz from what I've heard.
    The Logic is 0-12V I believe (I tested with a multimeter since I dont have a scope and got 12.84v on the +12v and a continually changing 6-8V on both Data and Clk lines as to be expected.)
    The Raspberry Pi has a 0 - 3.3V logic level, With anything above 2.8V being HIGH.
    Quesiton:
    My question is how best to connect these two, with the Pi purely just eavesdropping on the keybus - I dont need to write to it, just read from it.
    I'm concerned that if I dont have a high impedance circuit, that the Raspberry Pi will act as a drain on the circuit and disrupt communications between the alarm panels (BAD!).
    Possible Solutions:
    1. Use an Optocoupler - Not a good solution as I've heard they are slow and draw a lot of current on the transmitting side.
    2. Use a logic shifter chip - Possibly, but I dont know how to find the right one for my needs, and it has to have high impedance so as to not disrupt the keybus circuit.
    3. Use resistors as a voltage divider - This is the route I was planning on going. I calculated that the following:
    DATA -- 10kohm -- Pi GPIO -- 33.3kohm -- GND
    Will give 3v at the Pi when DATA goes to 12v, but will fry the GPIO pin if the voltage goes above 13.5v. It should provide 1.05mA to the Pi - I'm not sure if this is enough for input purposes.
    Further Reading:
    Resources I've found while researching this:
    http://electronics.stackexchange.com/questions/11017/dsc-keybus-protocol
    http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=104139
    http://www.house4hack.co.za/dsc-keybus-talk
    Any help / suggestions here would be greatly appreciated.
  2. ramesaliyev
    Aug 20, 2013
    Hello can you find any answer? I'm also looking for this information.
