Hello Guys,
i am just wondering if i can connect a 10 horsepower ac motor directly to the wall ?
so, what i need to make that happen.If you mean a standard main's wall outlet, no.
240 VAC 40 amp circuit.so, what i need to make that happen.
What is your country of origin?so, what i need to make that happen.
Yes it can be done. Most larger VFD's can be modified to work on higher powered single phase inputs as well. I've done several over the years for people.i just have a question stood in my mind, what if i used an AC drive (vfd) will that solve the problem ?
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Aaron Carman
