I am not an electrical engineer by profession. But I interact a lot with electrical engineers as part of my job.
Having said above, for an Oil and Gas project, we are trying to buy a 60Hz/254V powered convection heaters, the kind you find in hotel rooms for a room within a floating rig. we are not able to find a heater supplier matching above specs. what we are getting is 230V/50Hz.
I am aware that world is divided between either 50Hz/230V or 60Hz/110v as far as single phase AC is concerned. I am therefore assuming 60Hz/230V combination equipment would be hard to find.
1. what would happen if a 60Hz supply is given to 50Hz equipment?
2. what is the effect of 254V on a rated 230V equipment? do the standard equipment like heaters bought off catalogues have inherent margin?
It may be reasonable to assume that these heaters would come with some electronics for temperature control, and are generally powered internally.
A practical guide would be helpful.
