Connect power supply
Discussion in 'The Projects Forum' started by vnthuong, Nov 1, 2010.
  1. vnthuong
    Oct 25, 2010
    5
    I just have 12V power supply and IC NE5532. Datasheet of this IC say that it use ±12V, how to do that? who can help me? Thank you!
  2. wayneh
    Sep 9, 2010
    12,406
    3,256
    It'll work just fine with the GND pin connected to "0" and the Vcc pin connected to +12. This is equivalent to ±6v, which again is fine.
    Now, depending on what you want to DO with it, you might need to establish a "virtual ground", making 6v the new "ground", so that you have true ±6v. Such a technique is sometimes called a "rail splitter".
    But for many applications, a single supply is just fine.
    vnthuong likes this.
