Connect Piezo transducer to IC from USB Computer keyboard for sample trigger
Discussion in 'The Projects Forum' started by SteveSmith001, Oct 5, 2015.
  1. SteveSmith001
    Oct 5, 2015
    5
    Hi. I hope someone can help me with a suggestion for this.
    I need to connect a Piezo transducer to the IC from a USB computer keyboard, so that I can use it as an external trigger which can be hit with a drumstick.
    I have built a similar system using momentary switches, operated by hand, which works well
    However, when I connect the Piezo to the IC and connect this via USB to the computer, then the Piezo is triggered as a buzzer.
    I am guessing that this is because the USB buss has a voltage to drive external disk drives and similar appliances
    Can anyone therefore suggest what I can do to make the peizo function only as a trigger?
    All help gratefully received...
  2. Alec_t
    Sep 17, 2013
    5,976
    1,136
    Welcome to AAC!
    My crystal ball has gone cloudy ;). Can you post a schematic of your piezo input arrangement, and a link to the mystery IC?
  3. SteveSmith001
    Oct 5, 2015
    5
    Thank you very much for your response - Crystal Ball polish attached ;)
    I have attached two photos - one showing the USB IC (extracted from a computer keyboard) and one showing the piezo and the IC , not connected
    I have done this before by simply connecting the two poles of a switch to two connections on the IC
    When connected by USB to a laptop, this will generate the equivalent of a keypress on a keyboard. For example - if I connect pins 1 and 6 on the IC, the computer registers the letter 'a'
    As background - in case there are other thoughts on how to do this - I would like to be able to place the Piezo underneath a mouse mat, and when the mousemat is hit, it generates a letter...
    Please do let me know if any further information would help IMGP3523.JPG IMGP3522.JPG
  4. Yangui
    Oct 3, 2015
    8
    SteveSmith001 likes this.
  5. SteveSmith001
    Oct 5, 2015
    5
    Thanks very much for that link, and for taking the time to answer. I have done something similar when using piezos as trigger pads attached to an acoustic drum.
    My query here is whether it is possible to prevent the Piezo being triggered as a buzzer by the voltage from the USB buss, so that it just functions as a switch.
    Alternately - is anyone familiar with a better switching system for this application? What I need to do is make a set of pads, which can be hit with a stick, which each contain a switch which will connect the two poles of the Keyboard IC
    Something along these lines:-
    http://www.plugandwear.com/default.asp?mod=cpages&page_id=22
    Or this kind of thing:-
  6. SteveSmith001
    Oct 5, 2015
    5
    ... actually, to half answer my question - this sort of thing...
    https://www.adafruit.com/products/1361
    -may well be a better solution - the transducer requires not only to be amplified, but also converted to a pulsed switch signal...
  7. Yangui
    Oct 3, 2015
    8
    To stop it buzzing you could put diode in series , but may not solve your problem of switching by itself , you will need an amplifier stage .
    An alternative to Velostat is conductive foam used in packing IC's as an EMI shield , I have used this foam in a project as a variable resistance pressure mat.
  8. SteveSmith001
    Oct 5, 2015
    5
    The conductive foam is a good thought - time to buy some samples and get testing.
    Thank you for the suggestions
