Confusion with Dependent V Source using Nodal and Loop analysis
Discussion in 'Homework Help' started by ohmagod, May 17, 2012.
  1. ohmagod
    May 9, 2012
    I have been studying for intro to circuit analysis midterm. I've come across two problems that I do not fully understand even though I have looked up the answers on Cramster.
    3.82
    I approached this problem with loop analysis. First I related Io= I2-I3 , I3= -12mA , Ix= I1-I2 . I wrote out equations for the KVL around the L1( furthest left) and L2 (mid) . I ended up finding that I1=-9mA I2=-18mA. From this I found Io to be -6mA. When I looked up the answer it says that the Io= 0mA. Can you please tell me where I went wrong?
    3.84
    The directions say to use nodal analysis, but I don't know how to deal with the current around the dependent voltage source. The solution posted was very unclear. I don't expect you to solve it for me, any guidance will help a lot.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    For the first problem the middle loop KVL equation would be
    4000Ix=4000Ix-12000Io
    which immediately implies that Io=0 with the Ix terms cancelling out.
  3. ohmagod
    May 9, 2012
    thank you for your help. My attempt was unnecessarily complicated. Anyone have any tips for the second one?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    In the second problem there are two nodes.
    The node voltage on the left is
    V_1=-4000I_x \ \  ...\(1 \)
    At the right hand node - Vo node
    0.004=\frac{V_o}{10000} + I_x \ \  ...\(2 \)
    Another equation is required for a solution
    V_o-V_1=10000I_x \ \  ...\(3 \)
    Substitute equation (1) into (3) to eliminate V1 and simultaneously solve the result with equation (2) to find Vo
