Could anyone please help me point out whether there is current flow through the Rc resistor or not?
In the circuit Vin is 0.8V is connected directly between base and emitter of transistor without any resistor is used.Assume that the wire has zero resistor and internal resistor of source also is zero ohm, so the current Ib will be zero amp and Ic is also zero amp? Is it right? I am not sure about this?
Thanks.
Thanks.
