confusion in arithmetic addition
Discussion in 'Homework Help' started by annujain501, Jul 28, 2010.
  1. annujain501
    Jul 28, 2010
    6
    i am having hard time in addition of numbers in same base..!!! here are two of such questions
    1) (FE) + (78) = ? {all in base-16}
    using the logic as understand,solution i infer :
    FE
    78
    E+8=14+8=22---> 15+7---> F+7---> therefore,7 is carry
    7
    FE
    78
    F
    similarly 7 + F +7= F+E;
    7
    FE
    78
    EFF
    2) x567 +27x5 = 75yx (all in base-8)
    if i use the logic same as above,i get :
    x567
    27x5
    7+5= 12---> 5 is carry;x=7
    5
    x567
    27x5----> 2755
    75y7
    5+6+5=16--->7+8;y=7
    now 8+5+7=20----> this is obvly...wrong....
    where i m getting wrong..??
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Do the math in binary -
    (FE) 1111 1110
    (78) 0111 1000
    (176)1 0111 0110
    Convert to decimal - FE is 254, 78 is 120, sum is 374. 374d is 176h
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    There are all sorts of workarounds, such as converting to decimal or binary, but I hope you now see your basic error: there is a place holder for when the sum equals the base.
    Look at, for example, 8d + 2d = 0d plus carry 10 (or one "10").
    Eh +2h = 0h plus carry 10h (one 16, that is).
    Similarly, in your example and using your symbols, E + 8 = 14 +8 = 22 ---->6 plus carry 10 (one 16, that is).
    John
  4. annujain501
    Jul 28, 2010
    6
    one thing that i understood is that i cannot take 7 as carry because it not of the same radix system.
    okay,but i didnt got the idea of 'one "10"' carry
    and therefore in my problem 6 plus 10h as carry :(
    could you explain it in elaboration..??:)
  5. annujain501
    Jul 28, 2010
    6
    yes,this could be the way out but when we go for MCQs this procedure may consume time unnecessarily.
    so we go for a method that is both accurate and less time consuming.:)
  6. Papabravo
    Feb 24, 2006
    10,338
    1,850
    You need to make yourself a hexadecimal addition table. Then you do the problem in hex. For example:
    Code ( (Unknown Language)):
    1.
    2.   0xFE
    3. + 0x78
    4.
    5. E + 8 = 0x16 so you put down the 6 and carry the 1
    6. F + 7 + 1 = = 0x17 so you put down the 7 and carry the 1
    7. 1 + 0 = 1 so the answer is 0x176
    8.
    If we are dealing with 8-bit registers then of course the answer becomes 0x76 and the carry gets lost. That is what happens in modulo arithmetic
    Second problem requires an octal addition table. I do this stuff in my head because I learned it 51 years ago when I was in the 7th grade.
    1.
    2.   x567
    3. + 27x5
    4. -------
    5.   75yx
    6.
    7. 7 + 5 = 014 so x = 4 and we carry a 1
    8. 6 + 4 + 1 = 013 so y = 3 and we carry a 1
    9. 5 + 7 + 1 = 015 so we put down a 5 and carry a 1
    10. 4 + 2 + 1 = 007 so we put down the 7 and there is no carry
    11.
    AND - Tah dah everything is right with the world.
  7. annujain501
    Jul 28, 2010
    6
    thank u so much sir,i think this is exactly what i need to understand...
    but sir how do calculate E+8=0x16 and why have we taken FE as 0xFE? if i could understand this everything will become clear.
  8. annujain501
    Jul 28, 2010
    6
    thank u so much sir,now i got it,n after using addition tables any problem could be solved easliy thanks a lot.. :)
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  10. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Using a prefix of "0x" to denote a hexadecimal number is a convention I first learned in from "The C Programming Language" by Kernighan & Ritchie. Similarly a leading 0 denotes a number in octal (base-8) notation. I use these conventions almost without thinking and assume that everybody knows and understands them. It was presumptuous and I apologize.
