Hello, I am a bit confused with diode models and their application to a given circuit. I am currently working on these two problems and here's what I understand is the answer for them. I would appreciate if someone can double check me and correct me if it is wrong.
problem 1)
Since we are given current, and no DC voltage, I figure this is forward bias, thus V(in)=V(out) so graph would just be 2sint(wt) for Vout vs time.
Or is it sine graph with peak of 1V, without the negative component of sine wave?
problem 2)
This problem a bit harder, I think that the diode is going to be reversed biased with I = 25mA, but not sure what happens to V(out)
any suggestions will be appreciated, thx.
problem 1)
problem 2)
