Confused on which ESP to buy..!!
Discussion in 'General Electronics Chat' started by utilityhacker, Oct 20, 2015.
  1. utilityhacker
    May 1, 2014
    40
    Hello all. I'm planning to buy the esp8266 wifi module but there are a lot of versions out there and i cant decide which one to buy. Also to program the esp I have to buy a usb to TTL converter module and I can't decide which one to buy either, since there are a lot of them as well. I would really like to have some suggestions on this one.
  2. OBW0549
    Mar 2, 2015
    1,396
    941
  3. mcgyvr
    Oct 15, 2009
    4,793
    976
  4. utilityhacker
    May 1, 2014
    40
    That is of great help. Thankyou!
    Thanks for providing the link. At the end of the page i found another link to esp8266 wiki And found this Image
    I think i will go with the ESP-12 since it has more gpio and costs roughly around same as ESP-01
  5. OBW0549
    Mar 2, 2015
    1,396
    941
    I got a couple of those Huzzah ESP8266 modules from Adafruit, along with some ESP-01 modules; I'm eager to start playing with them.
    There's also this, which I haven't looked into yet: https://www.sparkfun.com/products/13231
    The ESP8266 has developed quite a following and there is a ton of info on the web. Here are some links I've found:
    http://www.esp8266.com/
    https://www.adafruit.com/product/2471
    http://www.instructables.com/id/An-inexpensive-IoT-enabler-using-ESP8266/?ALLSTEPS
    http://makezine.com/2015/04/01/esp8266-5-microcontroller-wi-fi-now-arduino-compatible/
    http://makezine.com/2015/04/01/installing-building-arduino-sketch-5-microcontroller/
    http://nodemcu.com/index_en.html
    http://forum.allaboutcircuits.com/threads/water-level-monitoring-through-wi-fi.110101/
    http://www.embedded.com/design/connectivity/4439644/Using-an-embedded-Web-server
    http://fab.cba.mit.edu/classes/863.14/tutorials/Programming/serialwifi.html
    https://nurdspace.nl/ESP8266
    https://github.com/esp8266/Arduino/releases
    https://forums.adafruit.com/viewtopic.php?f=53&t=74263
    https://forums.adafruit.com/viewtopic.php?f=53&t=73347
    https://forums.adafruit.com/viewtopic.php?f=53&t=73409
    http://jumpwire.io/?gclid=CjwKEAjww...8yCL7ra1IyPuYRZlePUHqrC7xOLqGfqTMiRoCy0Hw_wcB
    https://github.com/esp8266/esp8266-wiki/wiki
    https://www.openhomeautomation.net/getting-started-esp8266/
    http://www.electrodragon.com/w/ESP8266
    http://wiki.iteadstudio.com/ESP8266_Serial_WIFI_Module
    http://iot-playground.com/2-uncategorised/41-esp8266-ds18b20-temperature-sensor-arduino-ide
    http://randomnerdtutorials.com/esp8266-web-server/
  6. mcgyvr
    Oct 15, 2009
    4,793
    976
    Seen any with the FTDI chip/mini USB and ESP8266 all on one board?
    If not I may have to whip some up..
  7. OBW0549
    Mar 2, 2015
    1,396
    941
    Not so far.
    I can't imagine that would be very hard to do. I keep a stock of FTDI serial adapter cables (such as https://www.adafruit.com/products/70) on hand to deal with stuff like this.
  8. mcgyvr
    Oct 15, 2009
    4,793
    976
    yes.. simple
    I'd just like a 1 board solution that I can plug right in and go to town..
    Now to just find time between work and my "honey do list".... happy wife..happy life
  9. utilityhacker
    May 1, 2014
    40
    mcgyvr likes this.
  10. mcgyvr
    Oct 15, 2009
    4,793
    976
