Hey, could someone explain what's going on in the upper left of this schematic? The mic only seems to be connected to ground.
When you provide a link, try to be more specific. Ecelab has hundred of links on their main page.Ron, Check ecelab.com, they have the copy/original there - though without the word 'red'. I'm just trying to use an op amp to boost mic signal to blink a light. I.E. led. Need help; that's why I'm here, you awesome folks you are.
Here's a place to start:
That should work. Disable the unused op amp if you're not using it. One way to do this is to connect the + input to the junction of R2 and R3, and the output to the -input.Is it possible to swap the lm741 with a standard dual op amp like the 4580dd jrc?
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Jake Hertz
