confuse on solar charger circuit....help
Discussion in 'General Electronics Chat' started by hcchuar, Dec 18, 2008.
  1. hcchuar
    Nov 8, 2008
    23
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    If you look closely at the parts list provided in the article on this circuit, there is an entry that refers to the (1.8 ohm) 2 Ohm 100 Watt resistor as an "Optional Heater Resistor". The author appears to have taken some liberties with the schematic and is attempting to indicate that you can use the 1.8 Ohm 100 Watt resistor or you can simply replace the resistor with a direct connection.
    I believe your best course of action would be to email the designer and ask him for clarification on the pros and cons of using the resistor versus a direct connection.
    hgmjr
  3. hcchuar
    Nov 8, 2008
    23
    thanks hgmjr......
  4. floomdoggle
    Sep 1, 2008
    217
    That's the dump load.
    Dan
