Conflict between UART receive and transmit - RCREG seems to be loaded with TXREG con
Discussion in 'Embedded Systems and Microcontrollers' started by nikudnelog, Feb 12, 2014.
  1. nikudnelog
    Feb 12, 2014
    I am writing code for UART communication between my pic18f2550 and a bluetooth module. I have implemented receive by interrupt and do a manual transmit in my main loop. I've noticed that when I am not transmitting the receive works well and I am able to properly read whatever is sent to me. However when I send data through the UART from my microcontroller it seems that whatever I write to TXREG is also written to RCREG. This has been stumping me for a while and I was wondering if anyone could shed some light on what might be causing this?
    here is my uart set up:
    void uart_Setup(void) // init UART module for 19200bps baud, start bit 1, stopbit 1, parity NONE
    TRISCbits.TRISC7=1; //Make UART RX pin input
    TRISCbits.TRISC6=0; //Make UART TX pin output
    SPBRG = baud_rate_gen;
    SPBRGH = baud_rate_gen>>8;
    RCSTAbits.CREN=1; //1 = Enables receiver
    RCSTAbits.SPEN=1; //1 = Serial port enabled (configures RX/DT and TX/CK pins as serial port pins)
    BAUDCONbits.TXCKP=0; //not inverted
    BAUDCONbits.BRG16=1;//1 = 16-bit Baud Rate Generator – SPBRGH and SPBRG
    TXSTAbits.SYNC=0; //0 = Asynchronous mode
    TXSTAbits.BRGH=1; //1 = High speed
    TXSTAbits.TXEN=1; //1 = Transmit enabled
    PIE1bits.TXIE=1;
    PIE1bits.RCIE=1; //1 = Enables the EUSART receive interrupt
    INTCONbits.PEIE=0; //Enable Peripheral Interrupt
    PIR1bits.RCIF = 0;
    PIR1bits.TXIF = 0;
    here is my interrupt routine :
    #pragma code isr=0x08
    #pragma interrupt isr
    void isr(void)
    //Check if it is TMR0 Overflow ISR
    if(INTCONbits.TMR0IE && INTCONbits.TMR0IF)
    // TMR0 Overflow ISR
    counter++; //Increment Over Flow Counter
    if (counter==1000)
    sample_flag=TRUE; //set sampling flag
    counter=0;
    TMR0L=131;//start timer from 131 always, 125 counts of timer equivalent to 1 ms (256-125=131)
    //Clear Interrupt Flag
    if (PIE1bits.RCIE && PIR1bits.RCIF)
    USART_Status.val&=0xF2;
    if(RCSTAbits.FERR)
    USART_Status.FRAME_ERROR=1;
    if(RCSTAbits.OERR)
    USART_Status.OVERRUN_ERROR=1;
    RCSTAbits.CREN=0;
    RCSTAbits.CREN=1;
    rec_byte=ReadUSART();
    // if (rec_byte ==
    LATCbits.LATC2=!LATCbits.LATC2;
    dataToRead=TRUE;
    //clear interrupt flags at end of ISR, RCIF automatically cleared when RCREG read
    INTCONbits.TMR0IF=0;
    #pragma code
    Thanks in advance.
  2. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    I notice your interrupt won't be running!!! PEIE bit is not set!!
    As to the RCREG being loaded with TXREG, I'm not sure...
  3. JohnInTX
    Jun 26, 2012
    2,393
    1,051
    Is your bluetooth module running in half-duplex i.e. echos whatever is transmitted on TX to RX? Wiring error?
  4. nsaspook
    Aug 27, 2009
    3,009
    2,354
    The device you're sending data to might be 'echoing' it back as an ACK token like when in 'slave' mode.
