Confirmation of calcs for Wien Bridge Oscillator Circuit
jg80
Joined Mar 30, 2011
Iwas hoping someone could confirm the results I have for a Wien Bridge Oscillator Circuit?
The objective is to calculate a suitable value for Resistor 2 (see attached circuit), so that the circuit oscillates (sinusoidally). R1 = 100kΩ.
Vout = 0.4v. No other information is provided.
My attempt is as follows:
Vout = 0.4v; x 1/3* = 0.132v (Vin)
Amp Gain A = Vout/Vin = 0.4v/0.132v = 3.
Aβ must equal 1 when the phase shift equals 0 degrees. For maximum output voltage.
Therefore β = 1/A = 1/3 = 0.33v.
To find the value of R2:
β = R1/R1+ R2 where β =0.33v and R1 = 100kΩ.
Re-arranging;
R2 = (100kΩ/0.33v)-100kΩ = 203kΩ.
Questions:
*my understanding from my study material that this is a 1/3 of the Vout. I have also seen this as Vout is 1/3 of Vin???
Also can anyone confirm that my working is sound?
Thanks for your time.
Audioguru
Joined Dec 20, 2007
11,248
The extremely simple Wien Bridge oscillator has NOTHING to set its output level.
If it has enough gain to start (a gain of slightly more than 3) then its output will keep increasing until its opamp "hits the rails" and clips.
Most Wien Bridge oscillators use a non-linear network in the negative feedback (two diodes) or an automatic-gain-control system (an incandescent light bulb, a thermistor or a Jfet) to set the output level.
