I made a simple PCB by soldering. I tapped the multimeter probes over the solder line to test the connections using ohm-meter setting, and I found out that the surface of the solder is not very conductive (unless I press the probes into the solder metal). The circuit works though, means the components are connected correctly.
Is this normal?
Is this normal?
