conductivity of different metals
peteB1345
Joined Aug 25, 2010
If I had two bare wires, one of niobium and one of 18% nickel silver twisted together and I introduced a DC current in to both at one end and completed the circuit at the other end would the flow be equal or less in one or no flow in one according to the conductivity of each metal? (The niobium wire has a higher conductivity. )
Thanks for helping this complete novice, peteB1345
mik3
Joined Feb 4, 2008
4,843
This depends on the size of the wires. If they have the same length and the same diameter, the will be more current through the wire with the higher conductivity.
debjit625
Joined Apr 17, 2010
790
If you know the conductivity of the materials ,you are talking about then use ohms law
V = I * R
or I = V/R
V is the voltage of the source
R is the resistance of the material, and its the reciprocal of conductivity i.e.. 1/mho
Good Luck
marshallf3
Joined Jul 26, 2010
2,358
I first ran into the SI unit when we took over this new building about 2 years ago, it's one thing I have to monitor on the cooling tower water. What are we going to rename next?
