Condition Circuit
Discussion in 'General Electronics Chat' started by orwikcons, May 7, 2008.
  1. orwikcons
    May 2, 2008
    22
    D is permanent +12V (source).
    When +12V comes to A for a moment (pushbutton) circuit will connect D and C, and the consumer which feeds from C will send the +12V signal to the circuit via B. D and C will be disconnected when via B don't come +12V any more.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    This sounds like a homework assignment for a class. Is it?
  3. orwikcons
    May 2, 2008
    22
    Not the homework, but the circuit which will help me to make electric windows on my car close and open automatic (my car doesn't have that option, they move as long as I hold the button pressed).
    If it looks simple like homework at school to you, then solve it and show me the scheme, please!
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You can do this with a self-latching relay. The line for the latching voltage has to be interrupted by some device that will sense when the window has gone all the way up or down. The problem here is that if the sensor gets off, the motor will try to continue running and burn out.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What Beenthere said. :)
    However, most electric windows are "manual hold" for a reason - if someone (like a child) should stick a body part out the window when it was being rolled up, their body part may be snipped off. :eek:
    It would be one thing to have your windows automatically roll all the way down. Having them automatically roll up could prove very harmful to you and your passengers.
