Computer to TV video.
Discussion in 'The Projects Forum' started by Zatnikitelman, May 7, 2006.
  1. Zatnikitelman
    Thread Starter Active Member
    Jul 17, 2005
    31
    I am trying to build a device that takes a standard computer monitor output (those wacky blue cables) and turns it into a component video signal for a TV while still sending to a computer. This needs to be wireless or infrared.
    Could anyone please help me?
    Thanks,
    Zatnikitelman
  2. n9352527
    Oct 14, 2005
    1,198
    Sending the signal is not the big problem here. First, you need to convert the format from VGA (whatever the resolution you want) to video signal (whatever TV system you have). You can google for VGA signal standard and TV signal standard, read about them and proceed from there. Or.. this is the easy way out, you could buy a box that do the conversion and a wireless video sender and hook them up together.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Do you want to build this for fun & learning, or simply to be able to use it? If it is simply for utility, several such things are marketed already.
    One vendor
    Another vendor
