Computer sound level measring
Discussion in 'Computing and Networks' started by anaskoara, Mar 25, 2008.
  1. anaskoara
    Mar 25, 2008
    12
    Hi all
    I have software that produces sine wave sound and I want to measure the amplitude o f this sound and compare it with another sine wave sound produced by another device(not computer)
    how can I do that is AC voltmeter is enough or I should have oscilloscope
    best Wishes
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Oscilloscopes are best for visualization of wave shape. A meter is much better for measuring sine wave amplitude.
  3. anaskoara
    Mar 25, 2008
    12
    someone told me voltmeter can measure volt of 50hz or 60 HZ not
    I am not sure of that !
    can ordinary voltmeter measure volt of 1kHz?
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    Sound reflects off things indoors. The phase of the reflections could cancel some of the sound or add to it.
    Non-reverberant anechoic chambers are used to measure sound levels from speakers.
    I did it outdoors in a field with the speaker pointing straight up to the microphone that was hanging above it. There were no echoes to cause interference.
    An ordinary voltmeter is made to measure 50Hz or 60Hz and has less output at higher frequencies. The error is different for each range.
    Newer software makes an FFT signal or pink noise which are not affected by reflections as much as sine-waves.
  5. anaskoara
    Mar 25, 2008
    12
    Thank you for response
    do you think there is better way to measure the amplitude of sound measured by computer sound card it produce sine wave
    Is not enough to measure volt change that the sound card produce
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    A sound card does not produce sound. I don't think you want to measure sound.
    The sound card produces a sine-wave signal and I think you want to measure its AC voltage. Its amplitude is its AC voltage.
  7. anaskoara
    Mar 25, 2008
    12
    I am going to told you may problem and you please find me sloution I have device that produce sine wave sound at given frequency and I want computer to produce the exact sound from computer I can produce the sound with the same frequency but How can I be sure they have tha same amplitude thanks
