Computer PSU's in series
magnet18
Joined Dec 22, 2010
1,227
Hey, is it possible to wire two ATX power supplies or general computer power supply uinits in series to create a 24V source with low electrical noise and capable of providing ≈ 4A?
I know they have a -12V line but it isn't rated for the current. I also know these thigs are really complicated and I wasnt sure if it would be as simple as wiring batteries in series. I can do everything necessary to make it easy to use, I already have one set up as a benchtop supply, but other than what the wires colors mean (purple=standby +5V _ green=power on, input _ gray=power on, output _ blue=-12V _ white=-5V _ black=ground _ orange=+3.3V _ red=+5V _ yellow=+12V), but if both the ground lines are mains-grounded... I become confused.
Any help's appreciated, thanks :)
SgtWookie
Joined Jul 17, 2007
22,230
You can't do it safely, because the supply grounds (black wires) are connected to earth ground via the power plug. If you attempted to "float" one supply (not connected to earth ground) and there was an internal breakdown/failure, you could wind up with mains power on the chassis of the "floated" unit, which would be quite hazardous.
MPJA has a 24v 100W 4.5A switching supply for $32.80+shipping:
http://www.mpja.com/prodinfo.asp?number=16015+PS
BG Micro has a 24v 6.5A switching supply on sale for $15.40, but it uses Molex connectors of a type I don't recall seeing. If you can't get the correct connectors, you'd probably have to unsolder the Molex connectors and hard-wire it. The documentation available for it only covers the terminal strip type connections.
magnet18
Joined Dec 22, 2010
1,227
Thats what I was afraid of. :(
Thanks for the links, but since it only needs powered for a few seconds at a time (plasma speaker), I'll probably just stick with some sealed lead-acid batteries in the garage.
wayneh
Joined Sep 9, 2010
17,498
Batteries are simple enough.
It would also be possible to devise a scheme whereby a large capacitor is charged in parallel to your supply and then switched to be added in series with it, giving you a brief burst of voltage above your supply capability, dropping from 2X to 0X as the cap discharges. It goes to zero because the cap cannot pass a DC current. But the switching scheme can place it back in parallel for recharging once it has fallen to whatever level you want to switch on. The current while discharging would still be limited to whatever your supply is capable of.
magnet18
Joined Dec 22, 2010
1,227
What's the maximum speed that can be done at?
Is it possible to set up a switcher to switch rapidly enough to provide an apparent DC voltage if it's smoothed out?
Maybe if there were 2 caps, one charging while the other discharges?
Seconds might have been a bit of an understatement for the time this needs to be on, maybe a minuet or so at a go. (I'll probably use batteries, I'm just curious now)
Wendy
Joined Mar 24, 2008
23,421
Last couple I've bought had a wiring harness included. I don't know if this is universal, but the odds are good.
magnet18
Joined Dec 22, 2010
1,227
Would it be safe to wire one 12V battery in series with the ATX?
*unneccessary commment deleted
