Computer Logics and Digital Design: Operational Pair Grading System
laceyona
Joined Nov 21, 2011
12
Objectives
*Use of Boolean Algebra and/or Karnaugh Maps for Simplifications
*Multiple smaller system that builds a large system
*5 or more inputs that allows for mathematical process for simplifications
*Decoder
*Adder/Subtracter
*Storage Medium (Flip-Flops)
*Sequential Circuits (Timing Counter)
*Use of the AND Gate to control smaller system enable/disable
Description
Lippelli Warehouses requires an electrical system for measuring their operational workers whilst they are on the job.
The system is to monitor some specific attributes of each worker and directly use that information to grade the worker in relation to another worker.
Requirements
The system must accept from the user: the quantity produced by the worker, class of work of the worker, the mode of grading scheme to be used and display a Quality Level grade for that worker. It should perform this operation every six (6) seconds and needs to store the information for the last worker in order to get its results.
Inputs from each worker
For each worker the system requires three (3) forms of inputs which becomes that worker's attributes. They include: -
1.Product Quantity (Decimal Integer represented in Binary)
This numeric value represents the amount of units of the products that the worker has produced at the time system input. It is measured in pounds (lbs) and can range from 0 to 25 inclusive.
2.Class of Work (Decimal Integer represented in Binary)
This numeric value represents the class of work that the worker produces. 1 are Technical workers, 2 are Digital workers, 3 are Mechanical workers, 4 are Middleware workers and 5 are Electrical workers.
3.Quality of Work (Letter Value represented in Binary of the previous worker)
This symbol represents the quality of work that the current worker is known for. The values are: A (Best quality), B (Par quality) and C (Poor quality).
Outputs of the system
The system will display an output that will represent the current quality level of a worker based on their attributes as well as the attributes of their peers.
The three different values of the output will represent: -
1.Best Quality (A) – which means that the workers are producing the highest quality products
2.Par Quality (B) – which means that the workers are producing at the global standard level
3.Poor Quality (C) - which means that the workers are producing below Par Quality
Timing Process
The system is to ensure that it checks the current worker's attributes against the last worker's attributes every 6 seconds in order to produce the quality level of the current worker. There must be no other way of producing these results based on the input apart from the six (6) seconds to ensure that the process is periodical and efficient.
At every six second interval the system is to perform one of the three grading schemes listed below based on the inputs and the criteria available to it.
Modes of Grading Schemes
There are three (3) major kinds of grading schemes used by the required system on the inputs/attributes of the workers to make the correct display of Best (A), Par (B) or Poor (C) Quality for the current worker.
In order for the system to grade the current worker it also requires the attributes for the last worker to be processed by the system (i.e. the system must have some way of storing the current worker's attributes to be compared against the next worker).
The first worker to be processed by the system always gets a grade of Par Quality (B) because there is no worker to compare them to.
The following explains how the three (3) different modes of grading schemes work:
1.Class Grading Scheme. This grading scheme focuses of the different classes of the current and previous workers. It uses the following table to determine the grade of the current worker:
Current Worker -Previous Worker -Grade
Technical -Technical, Digital, Mechanical, Middleware -B
Technical -Electrical -A
Digital -Technical, Digital, Mechanical, Middleware, Electrical -A
Mechanical -Technical -C
Mechanical -Digital -B
Mechanical -Mechanical, Middlewarem Electrical -A
Middleware -Mechanical, Electrical -A
Middleware -Technical, Middleware -B
Middleware -Digital -C
Electrical -Electrical, Digital, Mechanical, Middleware -B
Electrical -Technical -A
2.Quality Grading Scheme. This grading scheme focuses on the quality given to the last/previous worker in relation to the current worker. If the previous worker has a Quality Level of Best (A) then the current worker gets a Quality Level of Best (A) if their quantity is greater than 10 lbs. If the previous worker has a Quality Level of Par (B) then the current worker gets a Quality Level of Best (A) if their quantity falls within the range of 5 to 20 inclusive. For all other cases the current worker gets a Quality Level of Poor (C).
3.Quantity Grading Scheme. This grading scheme focuses directly on the amount of production of the current and previous workers. The current worker gets a Quality Level of Best (A) if they produce more lbs than the previous worker; Par (B) if they produce the same amount of lbs as the previous worker and Poor (C) if they produce an amount below the previous worker's.
Deliverables
*Breakdown of the problem(showing how the problem was modularized in to smaller sections)
*Solution of each smaller section in relation to: -Truth Table
*Simplification using Boolean Algebra or Karnaugh Maps; or both
*Circuit Design based on simplification
30,824
You didn't say. So you want us to do this for you? When you want this done by? Tomorrow is quick enough? That would be generous of you. Most other posters ask for it urgently!!! Like ASAP.
Georacer
Joined Nov 25, 2009
5,182
You understand that what you ask and most of all, how you ask it, is impossible. You are presenting a digital design problem, probably homework which was given to you for a reason: To learn the subject and prove yourself worthy of a good grade.
We have no problem helping you with your project, but under no circumstances will we do your work for you. It is you that must dedicate time to design and build your system and when you face problems come to us for counseling.
strantor
Joined Oct 3, 2010
6,798
Why are you going to college? go home and save your money. or pick a different course that you are actually interesed in.
Georacer
Joined Nov 25, 2009
5,182
Strantor has used inappropriate for the occasion and possibly offending language.
But the fact remains that you presented a very large exercise problem with none of your work attached.
Do not expect any substantial help until you start posting efforts towards solving your own problem. If we don't know what you don't understand, we can't help you.
laceyona
Joined Nov 21, 2011
12
for a little good deed as looking over wat i've done so far even though i'm probably gonna fail this project anyway i have pay....how sad a life for me
