hi
if i am not wrong to start the computer SMPS it need more then 1 sec. (3 Sec.)
U are WRONG.!!
I think u know too much...or may be u are reading the wrong sources.
Who are you Mate ?
hi
thanks, but i guess i'll just sit down with multisim some time this weekend and figure it out
i mean really, it's in the fifth post of the thread do you get bored that easily?unfortunetly my bios not have the option to auto on after power off or is it does it doesn't work right.
I'm not quitting, i'm just going to mess with circuits on my own rather than asking for help and responded to by some people who seem to know what they're doing and some people who just want to pop in and make some funny or facetious comments about how i should be doing this a different way.it seams you are quitting?
do find the ckt. usefull ?
U are WRONG.!!
Who are you Mate ?
on my computer, it seems that any instantaneous short between the two will cause it to turn on.may be I am wrong
is it 3 Sec. or 3 mSec. may be but how much time it take
kindly update me
Why do you care if I double post or not.quit double posting, brings doubt to the fact that you're labeled a "Senior Member" you've already posted 3 times in this thread with little more to say than quit worrying because your BIOS can do it for you, which it cant--you would have read that earlier in the thread if you had read the whole thing
Of course i can breadboard the circuit. Computer Engineering student. There's a list of classes I've taken/ are taking I'm currently in the beginning or electronic devices/digital electronics. next semester I'll be taking Communications Systems.Why do you care if I double post or not.
As for member status, why don't look before u leap.
Anyways.
I said Bill has an answer for u. You do not need multisim to test it. Bill's circuits work. Besides ur problem is really simple.
Question is, can you bread board the circuit. ?
{ed}
Power button press switches on the mobo instantly. To switch off u need to hold the Pwr button for 4 secs. But this option too is available in bios to an instant OFF if u desire
assuming the +12v is one that is switched like the type for a hard drive or CD drive or the like, and that its a 12v relay then your computer will sucessfully turn itself back off but holding its power button right after you turned it on. if you switch the connections from points A to points B then it works the way that i desire. meaning that when the computer loses power the coil will lose its magnetic field, the contacts will fall back to the other side and press the power button. when the power button is pressed it will start the computer, which will start the +12v and pull the relay contacts back to being open for the computer.R!f@@ said:{ed}
OK i got it it was an error
pl . just check the ckt. in post #35
i think it can only be in ON State but how to OFF it?
Wouldn't this just be an endless loop. Parents turning off, relay turning on, instantly, and parents turning off again.assuming the +12v is one that is switched like the type for a hard drive or CD drive or the like, and that its a 12v relay then your computer will sucessfully turn itself back off but holding its power button right after you turned it on. if you switch the connections from points A to points B then it works the way that i desire. meaning that when the computer loses power the coil will lose its magnetic field, the contacts will fall back to the other side and press the power button. when the power button is pressed it will start the computer, which will start the +12v and pull the relay contacts back to being open for the computer.
If parents/other people turning it off was my primary concern, then yes. also my parents will probably give up the second or third time it turned itself right back on.Wouldn't this just be an endless loop. Parents turning off, relay turning on, instantly, and parents turning off again.
BTW: What software are you running?
right now, just teamviewer and my computer keeps becoming inaccessible because it's off. I'm looking to add some filesharing/VPN type software and possibly SQL soon so i'm trying to prevent problems before they rear their ugly heads. long story short, just personal stuff, nothing business or life threatening or i would take a different approach (probably a backup generator with auto-on and a UPS to cover the startup time for the generator.mines running mainly file server, but i also like to dabble in programming and i'm trying to write some software that will log some stuff and i want it to log back to my home computer when it can. (i may end up using SQL to add/update entries too)
I think you need to have a battery/wall socket. And as soon as power is lost/cut the timer starts, and when time is up, it triggers the power pins.
Like Bill_M said.
well obviously i cant do anything about this without being there.post #18;#23 ; #35 have the ans.
but only problem is no one should remove the power plug from the main
it does, but the onboard LAN has gone out and the card i replaced it with does not have the capabilityI guess not, but does your motherboard have a "Wake on LAN" - feature?
for you R!f@@. Just a general kind of how to behave nicely on forums.
but pl explanesorry bill it was an human error i write'd in reciprocal manner 3 sec is for turning off
So..lemme get this right.
Bill's circuit is not suitable for u.
If yes, and if I may, please.
I can draw u a circuit that can switch on ur PC and it can be powered via the PC Stby 5V.
But there are somethings that you should follow when implementing it.
So, Are u game ?
by Aaron Carman
by Duane Benson
by Aaron Carman
